Bottom of control building
The steel framing of bottom of a pre-manufactured control room is rusted and I am looking for a temp. solution to replace the steel floor. What is a most economical solution? underpimming and moving out the beams?
What is a method without moving objects refloor underneath
No drawings are avaialbe?
RE: Bottom of control building
Make sure the new steel is well coated. Try to figure out what's causing the corrosion and fix it.
