Problem with tolerance
I work in a company on Peru that we buy stainless steel over the world. We bought plates of different thicknesses, lengths and width. Our principal supplier is in Asia and I would like to know what kind of Astm standard for tolerances should I need to use. I am currently using the ASTM A480 for measure the tolerance but in the standard does not specify with accuracy tolerance for plates greater than 8mm.
Thanks.
Thanks.
RE: Problem with tolerance
for CS/LA see ASTM A-20
I would like to know what difference exist in the thickness tolerances between the norm ASTM A-240 y la ASTM A-480.
Thanks again.
