How to export sketch to DWG
I am trying to export some design I made in NX 10 to a .DWG file. The design is contained in a single sketch. However, when I export it (File>Export>AutoCAD DXF/DWG, formerly 2D Exchange), the converter somehow does not recognize this sketch, and outputs a .DWG file containing no features.
When I extract the individual curves of the sketch, using Menu>Insert>Associative Copy>Extract Geometry>Composite Curve (or just hand-draw the individual curves otuside of a sketch), the export works just fine; curves outside of the sketch are recognized correctly. (note that both the sketch and the extracted curves are located in Layer 1)
Is there a way to make the exporter recognize the sketch curves as well, without resorting to manually extracting all the curves in the sketch?
RE: How to export sketch to DWG
The export DXF/DWG works best with 2d drawings. One solution would be to switch to the drafting application and create a drawing view with the sketch and any other desired objects, then export the drawing to DWG.
www.nxjournaling.com
