Pedestrian Railing Height on a bridge
Section 13.8 says that a pedestrian railing has to be a minimum of 42" tall. If you have a traffic rail that separates the sidewalk from the traffic lanes (as opposed to a 8" barrier curb) does the traffic rail between the sidewalk and the lanes need to be 42" tall as well? Would the traffic rail between the traffic lanes and the sidewalk be considered a pedestrian railing even though it is a traffic rated barrier? I can't find anything in the AASHTO bridge code that specifically states the minimum height required. However the commentary on section 13.4 does seem to indicate that it needs to meet the minimum height for pedestrian railings. But the commentary isn't the code...
RE: Pedestrian Railing Height on a bridge
This is a project I worked on a few years ago.
I can think of one situation where a higher barrier is needed between the vehicle lanes and sidewalk. The (way overcapacity) bikeway/walkway on the Brooklyn Bridge is above the vehicle lanes, so it needs a higher barrier, too. I saw a proposal recently to add bike lanes on the beams spanning over the roadways. I don't know if it would work but the added capacity is certainly needed.
What would you call those members, anyway? Ceiling beams?
