PIPE THICKNESS
PIPE THICKNESS
PIPE THICKNESS
Why pipe thicknesses are identified as schedule 40 ,schedule 80 as well as standard schedule, extra strong, double extra strong? 200 NB schedule 80 has 12.7 mm thickness.200 NB schedule extra strong has also 12.7 mm thickness.
Then what is the difference in pipe procured with identification as 200 NB extra strong & 200 NB schedule 80?
RE: PIPE THICKNESS
Why?
A read of the foreword of ASME B 36.10 gives you an official history of such things.
"The original intent of the Committee was to establish a system of Schedule Numbers for pipe
size/wall thickness combinations which would have an approximately uniform relationship equal
to 1000 times the P/S expression contained in the modified Barlow formula for pipe wall thickness as defined in the Appendix* [no longer there] to this standard. The resulting Numbers departed so far from existing wall thicknesses in common use that the original intent could not be accomplished. The Schedule Numbers were then adopted strictly as a convenient designation system for use in ordering."
So take the last sentence (my bolding)as the Key one....
As for std, XS, XXS etc
"It was the hope in 1939 that the designation of pipe used commercially by all industry as
Standard weight, Extra-Strong, and Double Extra-Strong would gradually be replaced by Schedule
Number designation. However, owing to customs of over 50 years’ standing, demand and production
of pipe to these traditional dimensions is undiminished. Consequently, in response to a
demand from users, accepted practice for dimensions and weights of commercial wrought steel
and welded wrought iron pipe were added. These changes were designated an American Standard
on February 23, 1950."
Note the date here - 1939~!! And still we use them.
So for 8" (NPS 200) pipe there is no difference between XS and Sch 80. HOWEVER this is not valid for all pipe sizes, 2" to 8" yes, but then 10"XS = sch 60, 12 -14"XS is it's own thickness, 16" is sch 40 .....
RE: PIPE THICKNESS
LittleInch (Petroleum) - Thanks a lot for such a elaborate reply.
RE: PIPE THICKNESS
The forerunner of the ASME first published a standard of pipe sizes and thread dimensions in 1887.
In that day each boiler builder made pipe to whatever size suited them.
RE: PIPE THICKNESS
Note metric size is DN200, imperial size is 8NPS.
I have seen 40NPS as someone wanting 40" pipe when they really wanted 40mm (DN40)
RE: PIPE THICKNESS
KevinNZ,
Just to be careful on this, DN40 pipe is not 40mm OD. It is a metric equivalent to NPS1.5 pipe, so has an OD of 1.9in (48.3mm).
Equivalency chart
