Adding tool tip to reuse library dialog
Hi All,
I have made some custom reuse library parts. The option I am looking at to add tool tips for variable added in .krx and related excel file. Does anyone have this trick?
Amit
Amit
RE: Adding tool tip to reuse library dialog
Not that i know of, our solution was to add an url pmi containing a direct link to the reuse parts manual stored on the internal wiki.
That's Good idea!
The only limitation I found is that we reach documemt after feature/parts were added.
