CATIA VBA : collections does not work in catia vba in some computers
Hello everyone,
I have an issue with some computers running the same macro:
I create a collection to save selections.
then I want to use this collection to select the elements saved earlier in this collection (I can't do it by another way because I'm dealing with automatically generated PlanarSections for which ones I cannot chose the names. Otherwise I would have selected them thanks to their name but it is imposible).
Problem is that when I want to use the collection to select the elements, it does not work on some computers (all computers are using the same release of catia).
Is it some option that is not checked somewhere ?
CODE --> vba
oSelection.Search ("Name=" & geoSet)'a geometrical set in which one i have created my planarsections
oSelection.Search "CATPrtSearch.SkinFeature,sel"'to select in this geometrical set the planar sections(all of them)
For i = 1 To oSelection.Count
myCollection.Add oSelection.Item(i).Value ' to add in my selection all the planar sections
Next
For i = 1 To numSection ' number of planar sections
oSelection.Clear
oSelection.Search "CATPrtSearch.SkinFeature,all"'select all the mesh...
oSelection.VisProperties.SetShow 1'...to set them to invisible
oSelection.Clear
oSelection.Add myCollection.Item(i)'select the item "i" of my collection at each loop...
oSelection.VisProperties.SetShow 0'...in order to set them to visible one after the other
oSelection.Clear
Next Thanks
RE: CATIA VBA : collections does not work in catia vba in some computers
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
