PSL & PSH set point determination
How PSL& PSH set points are determined in a process flow lines like oil risers, separator, pumps and compressors ?
RE: PSL & PSH set point determination
Ashtree
"Any water can be made potable if you filter it through enough money"
Richard Feynman's Problem Solving Algorithm
1. Write down the problem.
2. Think very hard.
3. Write down the answer.
Its more typical to use such set ups in tanks etc as LSH/LSL but there probably are some pressure switches out there suitable for back up type applications.
The OP was requesting guidance on the establishment of setpoints more so than the hardware being used i guess.
Ashtree
This varies between companies and project but is often a set percent (say 5%) or minimum value (say 2 bar), with the larger one being used.
