Can I put Position control on a Radius
I've never come across this before so I turn to Eng-Tips
I have a checker marking up my drawing to add position control to a radius.
My thought is No. Because I'm thinking you need a complete hole or shaft to measure two opposing sides to derive the center to make sure it falls within the positional tolerance.
We are working with ASME Y14.5-1994 and I couldn't find anything specific in Section 5. But there are no examples of radii with positional tolerance.
RE: Can I put Position control on a Radius
Personally, I hate to apply anything but profile to a radius that under 90d or arc. Under 180d of arc I start to use caution, personally. Whether it's legal or not... I don't know absolutely, off the top of my head. I just want to add caution. It can be difficult to accurately measure/gauge such a requirement, in my experience.
My personal feelings may be guided by the heavy use of CMMs and laser scanners more than hard gauging, though.
Ask your checker how he thinks someone will inspect the feature.
JHG
You are right, position can only apply to a FOS(feature of size) or a pattern of FOS. Attached is a tip from Tec-Ease Aug.1999.
Season
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
In support of SeasonLee's and powerhound's answers, the following paragraphs from ASME Y14.5M-1994 should convince you (if you are not already) that your radius is not a feature of size:
pylfrm
This does NOT apply directly to your post about what are "regular" FOS. But from an "expanding your understanding" there are related terms to consider. For example: there are "irregular" features of size that are not "full" features but that can capture an actual mating envelope. Please see the attached.
Thanks for adding the important distinction! I assume everyone has migrated to 2009 since it been almost 10 years since its release (and 1994 is almost 25 year old technology)
