Hydrostatic test pressure ambiguity in API 5CT
My question is related to API 5CT (9th edition) code interpretation:
CASE STUDY:
The Tubing details are as below
Material Grade T-95 (yield strength = 95,000 psi, Size: 2-7/8", Wall thickness =0.217"
As per API 5CT clause 10.12.3, the formula being given for hydrostatic test pressure calculation as: p= (2 x f x YSmin x t ) /D
P= test pressure to be calculated; f= factor of safety (0.8 for T-95); YSmin = 95,000 psi; t=0.217" , D=2.875"
Now, calculated test pressure, P= 11,472 psi ( rounded to 11,500 psi )
However, in the same clause (API 5CT clause 10.12.3), it’s been mentioned as “ maximum test pressure shall be limited to 10,000 psi ”.
Why such contradiction between two values ( 11,500 psi V/S 10,000 psi) ?
Which one should be chosen (11,500 psi or 10,000 psi) when we conduct pressure test?
CASE STUDY:
RE: Hydrostatic test pressure ambiguity in API 5CT
Can anyone helm me out in answering my query ?
And the added stress from the higher pressure is not significant.
Most Code requirements have similar rules, though often they also add 'unless higher pressures are agreed to'.
