ASME IX QW-200.4
ASME IX QW-200.4
Hello everybody,
I have two PQRs both welded utilizing SMAW process. One with 7.11mm plate and the other with 25mm plate. Combining these two PQRs to support one WPS, what is the base metal thickness range and maximum deposited weld metal qualified. Impact test is not required.
RE: ASME IX QW-200.4
