Moment Frames permitted in Single Family Homes
The Subject sounds like a dumb question. I have designed ordinary moment frames in countless single family homes over the years. But today I found myself carefully reading section 12.3.1.1 of ASCE 7-05 (it's the only copy I own. It states that a plywood diaphragm my be idealized as flexible "in structures in which the vertical elements are steel or composite steel and concrete braced frames, or concrete, masonry, steel, or composite shear walls." Note that it does not include "moment frames" under the vertical elements.
The next sentence allows the flexible diaphragm assumption in single family homes that are "of light-frame construction".
When I brace homes with steel frames, then the home is not completely "light-frame construction".
I may be splitting hairs. I know we all include moment frames in single-family homes. But has anyone noticed this before? Ever had it come in in plan check?
RE: Moment Frames permitted in Single Family Homes
