Difference between ARMS and Picatinny rails?
Hi all,
as the title states, what is the difference between the rails?
I found the correct dimensions for the Picatinny rail but nothing on the ARMS.
Thanks!
Thanks!
RE: Difference between ARMS and Picatinny rails?
A.R.M.S. is a company that has made different flavors of dovetail rail, including the design which became the MIL-STD-1913 rail.
If you mean any other rail, like Weaver.. it's less standard and companies would make their own Weaver-mod rail. Companies are not very likely to publish full specs on non-standard products they market.
Is there a specific ARMS product you're curious about, or what.
So if i got you right, the two rails are basically the same, or more accurately the Picatinny is a standardized to mil-spec ARMS rail.
Buy the part you're supposed to make it mate to. Make it mate to it. Allow for reasonable variance.
I prefer to try and fined the technical drawings/official dimensions of the product.
It's better to know the 'nominals' for a more accurate target, I agree, but with a part in-hand you also get to do testing of your product right away, and then use it for marketing/demonstration purposes if needed later. Potayto, potahto, c'est la vie, etc etc
Good luck
TTFN (ta ta for now)
"A.R.M.S.®, Inc. is the original designer and manufacturer of the dovetail dimensions for Military and Civilian use since 1980. Those original A.R.M.S.® dovetail dimensions were eventually adopted in 1995 as the Mil-Std 1913 Rail."
I had a thread about the 1913 drawing and how it's not very good: http://www.eng-tips.com/viewthread.cfm?qid=406027
Pylfrm presented a reasonable interpretation at the end of that thread. It bugs me deeply that the standard drawing is poor. I work with it semi-regularly. Many rails on the market would not meet any reasonable interpretation of the drawing, but stuff still works...usually. Lots of rails are extruded with no secondary machining, but extrusion alone can't reliably conform to the "drawing" in my experience. Life goes on.
This is one of those cases where contacting the original designer of the rails should be the best bet, but since they would have supplied the drawings to create the MIL-STD, they would also be the ones who didn't understand** how to document the requirements in a usable fashion. The diagram was revised in 1999 and they made it worse.
http://quicksearch.dla.mil/qsDocDetails.aspx?ident... should be the MIL-STD-1913 page.
**Or they do understand and want their competitors to be at a distinct disadvantage due to the incomplete spec, including you.
Unlikely, given that EVERYTHING that you want to attach to the rails also need to be standardized, such as scopes, lasers, grenade launchers, etc., so they all need to be able to reconcile tolerances and dimensions to meet their requirements, and the requirement typically calls out only MIL-STD-1913:
3.2.14 Mounting Interface
The XXX mLRF shall be capable of being mounted and aligned to a weapon platform via the MIL-STD 1913 rail interface system (Picatinny Rail). The XXX mLRF will be mountable and fully functional on either the top or right side rail without modification to cables or connectors.
However, anything that attaches to the rail has an extra degree of freedom, since they typically clamp to the rail with an adjustable mechanism.
Mil-spec small parts drawings like this are always bare bones. It defines enough dimensions to build a part that is functional- it isn't, and isn't intended to be, a drawing you can hand to a fabricator so they can build a part without any additional information.
The second one looks to me like a different draftsman just opened it in his own autocad seat with different leader/arrow settings and didn't fix them for legibility before saving the drawing.
The update mis-typed the datum reference from [C(m)] as [-C-(m)] for the .835 -.005 dimension.
What is the purpose of this drawing?
How do accessories actually interface with this shape?
Everyone seems to be focused intently on how the angled sections of the shape are dimensioned and related- what seems to be missing is the simple fact that in the real world, the angles of those faces being incredibly precise doesn't really matter that much.
I would never call this a great drawing, but from what I can tell if I needed to design something to mate with this shape, there's enough information there for me to do it.
The intent is not a precision mount, per se, but a reasonably precisely repeatable mounting.
But yea, I think that drawing is why some folk think "Good enough for gov't work" doesn't mean "Rigorously evaluated to comply with standards that ensure a reasonably low risk of mission failure, loss of life, or loss of vehicle" lol
The point of the 1913 rail isn't to provide sub-micron positioning of accessories- its to allow a zillion different things to be mounted in whatever configuration is required, quickly and without much fuss. It accomplishes that pretty effectively even though it's governed by a drawing that isn't first class.
I would argue that if the drawing had no tolerances at all, nothing would change out in the real world. Why? The tolerances currently on the drawing are as effective as no tolerances at all...uninterpretable.
Modern manufacturing equipment can easily produce rail that is "close enough" with no human confirmation. Most rail is not checked and nobody cares. Rail that is checked...what drawing is it checked against?
This is all fine and dandy...until you are responsible for a 100% PPAP on a part with the 1913 profile. Then what? I gave up trying to explain to people that the drawing is bogus. As in most similar cases, just fill out the swiss cheese PPAP and submit it...so the customer can ignore it...along with all the other paperwork they fudge to follow their approved ISO plan.
The XXX must be capable of repeating bore sight/zero after removal and re-installation on its supporting weapon. When set to the neutral position and mounted to an M4/M4A1 on the Picatinny Rail, and then fully detached from the secured bracket, the XXX final beam position shall be within 0.5 mrad of the initial beam position. "
That would be a 0.5 m repeatability at 1000 m; had the requirement been 0.125 m repeatability, I think we could have met that. The spec as written was only intended for a weapon where the max range would have been around 500 m. Nevertheless, assuming a low dispersion round, the odds of hitting center of mass are pretty good, had this been a rifle sight.
