calculating the combined ring-shell section I'
When you try to compare the combined ring-shell sections, the required moment of inertia is I's formula which is straight forward. But when calculating the combined ring-shell section I' - what is the cross sectional area of the shell section contributing to the moment of inertia? Is it the nominal shell thickness (ts) * 1.10*sqrt(Do*ts) or ts minus the thickness required to withstand external pressure * 1.1*sqrt(Do*ts)?
Monk
Monk
RE: calculating the combined ring-shell section I'
Mike
Monk
Note that I' is computed on the composite ring-shell section per the parallel axis theorem with the width of shell section contributing as noted in the definition of I'.
Mike
