OLD GE CONTACTOR IC2800106
DEAR SR have any one know the best option to replace an old contactor ic28001607 those unit are not available any more , ill appreciate comments and tips
regard
amper
regard
amper
RE: OLD GE CONTACTOR IC2800106
From the photo is appears you have a 38VDC coil? That's going to be tough. One company that still sells DC contactors like this is Hubbell Industrial Controls. They have been buying up older defunct product lines from other larger mfrs who wanted out of having to support them and making them available for people like you that are trying to limp along with old technology for a while longer. I'd give them a call, but have all of the rest of your information ready, i.e. EXACTLY what control (coil) voltage you need, any auxiliary contacts etc. Good luck.
http://www.hubbell-icd.com/icd/components/dc5210.a...
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Does the replacement need to be GE? Why not ABB, Siemens or SquareD?
GG
"I have not failed. I've just found 10,000 ways that won't work." Thomas Alva Edison (1847-1931)
