Alfa 3 Amada laser
Alfa 3 Amada laser
Does anyone know which parameter on the Alfa 3 4kw amada lasercutter, you have to adjust to get the interference in crc to not show.
I know you could change a setting on the amada Fo so it would not appear on small errors.
Any ideas? Because the same dxf works fine on the fo but not on the alfa.
Thanks for any help
Thanks for any help
RE: Alfa 3 Amada laser
