Tiny test pins. Stolen from Missus...
3
Skogsgurra (Electrical)
I got soo tired when trying to connect to a little breadboard weighing around ten grammes and using test clips/cables with 1 mm2 Cu cables. The tiny EZE-hooks dont't work very well if you need to attach to female connectors and they can't be used to probe tiny IC pads.
So I took a tour around the house and found this:
Great for little projects. You can even stack them by sticking them into the cable. Color coding is in the pin-head.
And - if you haven't tried Blockly yet: DO! It is serious stuff in LEGO disguise.
Gunnar Englund
www.gke.org
RE: Tiny test pins. Stolen from Missus...
Keith Cress
Yes VE1 - there was some blood-shed. Those pins need a woman's delicate and trained fingers.
Gunnar Englund
www.gke.org
aka a small piece of an aluminum beer can metal used to fix the slipping handlebars on a BMW motorcycle.. re: Zen and the Art of Motorcycle Maintenance...
TTFN (ta ta for now)
Blockly?
I got the turtle to level 10...
Whatcha doing with your propeller?
STF
But it will turn into a shaft voltage supervision and alarm thingy when I got all mechanical details and environment (heat, oil mist, vibrations and heavy EMI - running on VFD/PWM controlled motors up to a few megawatts size) under control.
The reason I use the propeller is that I can switch between 96 MHz and around 20 kHz by setting a few bits in the clock register. And, yes, I usually feed the display from one of the output pins. Idling at around 25 uA. Of course, the parallel processors and the flexible A and B counters are also used fully.
Gunnar Englund
www.gke.org
