AC Motor Wiring ?
AC Motor Wiring ?
I've made several attempts at wiring this small AC motor but can't seem to get it to work. I'm sure the answer is right in front of me but I'm not sure how to interpret the schematic. Any assistance would be appreciated.
Thank you.
Thank you.
RE: AC Motor Wiring ?
There should be a 20uF capacitor with the motor, typically a plastic or aluminium can about 1.5" diameter and maybe 4" long. That's 'C' on the diagram, connect it to the red and orange leads.
There's a thermal overload which looks like it is a self-resetting Klixon type. Your should be able to verify continuity between the white and red leads to prove it is OK.
Thanks again.
It should be rated for continuous duty, not a starting capacitor.
Bill
"Why not the best?"
Jimmy Carter
After some research, I believe the capacitor causes a 90-degree phase shift which determines the rotation direction of the motor. Moving the capacitor to the other winding should reverse the rotation direction. Is my understanding correct?
A trick I've used on very small shaded pole motors - which are inherently non-reversible - is to dismantle the motor and physically reverse the rotor so that the shaft is at the other end, assuming the bearings and end-bells allow you to do this. You may have the option here, and I think it should be simple enough on this motor because it looks like a permanent split capacitor motor rather than a cap start, induction run type. The latter can be fiddly because of an internal shaft-mounted switch which disconnects the start winding once the motor is at running speed, but I don't think that's what you have here.
There is one exception. There is a type of small motor with two identical windings that is reversed by switching the capacitor from one winding to the other. Your motor is not such a type.
I agree with Scotty's suggestion.
Bill
"Why not the best?"
Jimmy Carter
