Precast Concrete Vertical & Laretal Forces Resisting System
As far as I have encoutered the combinations of External Moment Resisting Frames & Internal Shear Walls, External Shear Walls & Internal Moment Resisting Frames, Moment Resisting frames are comminly used in precast concrte buildings with the Moment Resisting Frames specially for one storey buildings.
A local contractor in the middle east insists of using only Shear walls in a H type one storey building of 45mx40m with plenty of protrusions in plan.
The building is in average seismic zone with pga of 0.19g
Shear walls aren't aligned in the transvesre direction.....
His layout is far from any rectangular shapes with unclear force flow paths..basically against the PCI general guidelines
The plan is not PCI accredite.
Has anyone got experience of such structural system ?
Had him divide the volume in three distinct structural volumes bu the anomalies rgarding shear wall are there...
Appreciate an answer as he is in the conceptul design stage.
RE: Precast Concrete Vertical & Laretal Forces Resisting System
