RFID circuit problem
Hi everyone,
I have a problem and i hope that someone can help with it,
I have designed a circuit that contains the following;
- controller
- custom RFID reader circuit based on MFRC522 including matching circuit and EMC filters
- indication (leds and LCD)
- logic level converter
- the circuit is powered by a power 5v power supply
I have a problem that sometimes RFID reader fails to work, and the circuit seems to be holding much of static charges,
but when i touch any terminal (and the charge is dissipated), the reader works again after resetting the system,
Can anyone help me with this issue,
Thanks in advance,
ATarek
- controller
Thanks in advance,
ATarek
RE: RFID circuit problem
Dan - Owner
http://www.Hi-TecDesigns.com
Since you have to reset, why wouldn't Occam's Razor point to your controller getting lost in its code?
Your description claims a 5V power supply, so there is already a static dissipative path through the supply, and therefore, it's unlikely for there to be static charge in the normal sense. That said, it's not unlikely that you left floating nodes in your circuit that have floated into undesirable states.
TTFN (ta ta for now)
I think the problem is floating nodes as IRstuff said,
Am i supposed to leave no floating pins in every chip (microcontroller, logic IC, MFRC522), and what is the best method of doing this,
and if the project will take another phase and be supplied with battery, is there something else to be considered???
Thanks in advance,
Atarek
Your question about battery power is irrelevant; there are literally BILLIONS of circuits that are battery powered, such as your phone, which have ZERO problems with locking up, static electricity or otherwise. A common mode on a circuit is mostly irrelevant if it does not have to physically be connected. There are millions of Rokus with RF remotes that have ZERO problems with lock up.
Your static problem is most likely a wild goose chase.
Outputs are (generally) fine being left unconnected. Inputs, not so much... not only can they lead to odd modes of operation, they can waste precious power in battery-operated circuits.
Dan - Owner
Atarek
