An issue with the Hole Callout feature
I went to File>utilities>customer defaults>drafting>general>Standard then clicked Customize Standard, then selected Hole Callout, then made some changes and did a save as. Then, closed and re-opened NX. However, the changes do not seem to be taking effect. When I go back and look, my new standard is there but for whatever reason NX doesn't seem to be using it. Is there a way to get NX to use my new standard as the default for each new drawing I create?
Thank you
Thank you,
Trent
NX 9.0.3.4
RE: An issue with the Hole Callout feature
There's a setting in the customer defaults to set whether to use the standard or template when creating a new drawing.
My guess is that in your case it's set to use the drafting template.
You may find an easier way is to open the template you use and edit the preference (not default) to change whenever that template is used.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
