Glue and Surface to Surface contact
Hi everybody!!
I have a big problem. I need to use both, glue and surface to surface contact properties, but at the same time in a model.
What can I do?
Do I have to exporte the model and then rewrite .dat file?
I know that NX. has an option for these questions.
Regard!
RE: Glue and Surface to Surface contact
In FEMAP you can create any number of connection properties and assign them to different connection regions, including glued contact and surface to surface contact.
