Beam Minimum Width ,b
As per SMRC condition minimum beam width is 10" , also b/d>=.3 . But my question is there any condition on beam minimum width depending beam length .As per Susil kumar min of ( 50b or 250b^2/d) . So if i choose b=1ft d= 4ft ,maximum span length can be 50 ft. Can any one clarify this issue and give me a few more reference on beam minimum width depending on span . Thanks in advance
RE: Beam Minimum Width ,b
Read your design code!
Based on the equations cited, I'm guess that they pertain to lateral torsional buckling when the beam in question is unbraced by an integrally poured slab.
For an I-beam, its good practice to make H/B < 2 for the following reasons:
a) The buckling reduction factors are usually less onerous (this is the case for the Eurocodes anyway).
b) Tall and narrow things like to topple over - not good for H+S!
Concrete grade beams do not always follow the above prescription. The width of a grade beam may be selected to match the thickness of the wall bearing on it. Eight inches is quite common in my neck of the woods although I have seen widths as little as six inches. Depths may be dictated by exterior grade and can be 48" or more. Sometimes, a grade beam is laterally braced by dowels from the grade slab but sometimes it butts up to a slab on the inside and retains earth on the outside.
BA
