Using a formula or parameter as input for points instances function
I'm using the points and planes function in wireframe workbench and I'm having trouble assigning an integer parameter to the "instances" field. Usually catia allows for editing the formula and assign a user defined parameter but in this case I only have the option of "change step" or "add range". Please help as I would like to define the number of points on curve using a parameter and not to go into the function to change it each time.
