Spline compatibility DIN5480 v AND20002
I have a generator with a 16 tooth spline shaft to the DIN 5480 spec. I need to mate with an internal 16 tooth spline to AND20002. The two specs are nearly identical and, as far as I can tell, will mate. The only difference I can see is the pitch diameter of the DIN shaft is 20.000 mm and the AND receptacle is 0.800”. The shaft pitch diameter is 0.0126” smaller than the receptacle which is significant but may simply be the built in clearance for the male and female. I cannot help but think that they were intended to mate, can anyone confirm?
RE: Spline compatibility DIN5480 v AND20002
A good reference for the mating spline connections used in AND type standard aircraft accessory drives is MS3335.
