Pressure drop though annular region between two concentric cylinders
Has anyone seen a good correlation for calculating friction loss in the annular region between two concentric cylinders?
RE: Pressure drop though annular region between two concentric cylinders
2. Look here - FAQ378-1142: Flow in Annular Space
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Again, many thanks.
