Centerless Grinding
Centerless Grinding
Centerless Grinding
Hi
I have recently rebuilt a Cincinatti No 2 OM grinder, had all the bedways reground, stripped and checked main spindle and replaced bearings on regulating wheel spindle ( machine was modified to take bearings)
On commissioning I found that every time you dress the grinding wheel you need to adjust the angle of the bed to compensate for the taper (grinding engine valves) I checked for play on dresser and dresser quill there is none, dresser was clocked square to spindle. Any advise is highly appreciated as my customer is peeved.
RE: Centerless Grinding
I would suggest you contact the manufacturer and find out how they calibrate the machine....here is a link to the manufacturer.....
Cincinnati Grinding Machines
You might try asking here www.practicalmachinist.com.
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
