ILI gauging tool
ILI gauging tool
Hi Sirs,
Could you give me a normative reference for the selection of the thickness of the calibrator plates in the internal inspection of pipelines.
Thank you for the attention you can give me
RE: ILI gauging tool
Do you mean some sort of calibration plate for an IP to calibrate itself on or something different?
If the former, normally this is part of the specification you issue or part of the vendors calibration procedure which he submits for your approval. I'm not aware of a normative reference, but that doesn't mean there isn't one.
I'm sure a friendly Intelligent pig vendor can assist.
I'm talking about the calibration plate of pigging tool for pipeline insternal inspection. It being known that depending on the size of the pig, the thickness of the gauging plate can be 1/8″, 1/4″, 3/8″ and 1/2″ thick. But I would like to know the most advisable way of selecting this thickness. In our case the lines are of diameters 8" and 12" and the engineering was narrow in this way within the job specifications.
Depends what thickness type pipe is I suppose?
