Geometry Import Failed in ANSYS WB 17.2
Good afternoon
In workbench 17.2, when I try to model the structure (simple supported beam), the following error messages appear and the link to Ansys mechanical aborts:
"Unable to attach to geometry file C:\Users\André Luiz\AppData\Local\Temp\WB_TABLET-PC_André Luiz_24816_2\unsaved_project_files\dp0\SYS\DM\SYS.scdoc. Unable to attach geometry."
"PlugIn Error: Attach failed."
"PlugIn Error: Failed to import assembly from SpaceClaim. Erro HRESULT E_FAIL foi retornado de uma chamada para o componente COM."
I´ve tried to solve using Ansys configuration manager, but didn´t succeed.
If anyone has experienced this and know how to solve, I´ll really be thankful.
Thank you a lot.
RE: Geometry Import Failed in ANSYS WB 17.2
Are modelling the beam using line bodies? In that case did you assign a cross section in Spaceclaim for the bodies?
Thank you for the response.
I´m attaching my model, so you can see what I did using SpaceClaim design modeler.
