Elevated Commercial Washer
I've got a hotel job where the architect would like to place a commercial washer/extractor on the elevated slab on metal deck (On Housekeeping Pad). The unit is only about 1000# unloaded, but spec sheet give a frequency of 16.8Hz and a floor load at max extraction of roughly 1500#.
1. Does unit need to be placed on a fully isolated support or is there a way to justify or isolate vibration on primary building slab?
2. If unit is placed on isolated frame, what procedure should be used for design of isolated frame system for dynamic loading?
Thanks!
Thanks!
RE: Elevated Commercial Washer
