Toggle Switch In A 115V AC Motor Conduit Box
For many years, my company has installed on/off SPST toggle switches in the conduit box(peckerhead) of 115V motors up to 1 hp with no reported failures. A man in our shop says there is a code stating that 1 hp is the limit for this configuration. In the past, when we went above 1 hp, we have gone to a manual motor starter in a separate box. Does anyone know if there is such a code regarding the 1 hp limit for putting a toggle switch in the motor conduit box?
RE: Toggle Switch In A 115V AC Motor Conduit Box
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
