API 6A Secondary Stresses
API 6A section 4.3.3.6 for non standard materials limits the hydro membrane, stress intensity at working pressure, and primary + secondary stress limits as follows:
ST = min[(5/6) x Sy, (2/3) x Rm]
Sm = min [(2/3) x Sy, (1/2) x Rm]
Ss = min [2xSy, Rm]
My question is can the primary + secondary stresses for the hydro-test case scenario be taken as St x 3.0 as in ASME VIII, Div 2?
Surely the hydro-test case would not be limited to the above Ss for design working pressure, right?
Thank you in advance for your help.
RE: API 6A Secondary Stresses
Please note that according to VIII-2, there is NO LIMIT on the secondary membrane-plus-bending stresses for the test condition.
WHY?
Well, the secondary stress limits are to manage a failure mode called Ratcheting. However, ratcheting requires repetition for the loading. A hydrostatic test only occurs once. So, no possibility of ratcheting.
