API 650 storage tank roof type selection based on tank diameters
Hi everyone,
Please tell a thumb rule for the selection of a roof type (self supported, rafter supported, rafter+column and dome) based on the diameter of a storage tank being designed in accordance with API 650
As i have read, the storage tank guide book by Bob Long gives the following criteria for the the roof selection of the tanks based on diameters
For tanks upto 8 metres in diameter: Self supporting cone roof
For tanks upto 15 m in diameter: Rafter supported roof
For tanks greater than 15 m: Go for rafters+columns or truss structure
But i have also seen that if, for example you increase the angle for a self supporting cone roof, say between 15 to 19 degrees, you can have the roof to pass as a self supporting structure, even for a 12 metres diameter tank
Please if you guys can share anything, you are welcome to do so.
