The meaning of "F3 Break" callout
Just want to know what is the meaning of "F3 Break" callout as circled on the figure, drawing in accordance with ASME Y14.5M.
Thanks for the assists
Season
Season
RE: The meaning of "F3 Break" callout
Season
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
http://www.thefabricator.com/article/finishing/deb...-
Thanks lot.
Season
From Fig.3 I got F means ECD(Electrochemical Deburring---process to remove burrs from metals), but I am not quite sure what means of 3.
Season
Season
Are there any other applicable specifications referenced on the drawing you can avail yourself to?
I can't find any other applicable specifications on the drawing, do you have any applicable examples?
Season
May I ask 25% of what? it based on which standards or specifications?
Thanks for your assists
Season
Yes, there are 3 applicable specifications: S-981, Sme -942-E2 and S-1000C in the frame. what these specifications are? Thanks for you guide me walking the right way.
Season
Thanks for the direction you showed to me.
Season
Try this: http://www.thefabricator.com/article/finishing/deburring-a-standard-operation-
If that doesn't work, add a "-" character to the end of the broken links previously posted.
pylfrm
