Torque valuu calculation for Air Cooler header plugs
Can anyone help me out in with a formula for calculating the torque value for a header shoulder plug on an air cooler?
RE: Torque valuu calculation for Air Cooler header plugs
ehouston69,
Are you designing this? There is all sorts of literature out there for calculating screw torques. There are also all sorts of assumptions behind your calculations.
If you are not designing it, have you called the manufacturer?
JHG
