Forcing G43.4 (TCP) for 3+2 axis operation
Is there a way a 5 axis UG postprocessor (for example one of those in installed machines folder)
to output G43.4 instead of G68/G68.2 format ??
I know that 3+2 should be preferred (arcs, rad. comp, canned cycles) but I need the TCP output for a particular case.
I have tried with choosing "G1-Feed Mode" for Rapid. Did not work.
Thank you !
