IINTERGRANULAR CORROSION IN THE HEAD OF SA240-TP304L?
hi every body
we want to make 2 head from SA240-TP304L,ID=6000 mm, knuckle should be maked by hot spinning,(temp=900~925 degree c),can i sure any intergeranular corrosion,don't happen in this head?help me, i a'm waiting for your answer.
thanks.
thanks.
RE: IINTERGRANULAR CORROSION IN THE HEAD OF SA240-TP304L?
For futher reading see www.nidi.org.
rama33
