SOL601 error when I use 'Force balance' option
Please refer to the attached screenshots. I get this error only when the force balance is checked. What could be the reason here? I am using the force balance output to get the net resultant shear force in the bolt region made of solid elements.
Thanks and best regards,
Su
Su
RE: SOL601 error when I use 'Force balance' option
Femap 11.2.1 and later releases have the updated(10.2) solver and should work fine.
Joe
