Attribute link
Attribute link
Attribute link
I'm trying to make attribute link in my drafting with model.When I make AL for example nomenclature in drafting, and change nomenclature in catpart,that change is not updated in drafting.Why?
RE: Attribute link
Try doing a c:Force Update in the Power Input bar. I don't believe the Attribute modification will be enough to flag the DrawingView update flag to fire in certain scenarios.
RE: Attribute link
Attribute modification won't cause title block text update. Also colors won't be updated if you change change model color. As dougsnell said use force update.
Jenia Ladkov
RE: Attribute link
c:Force Update -This one works-thank you!
RE: Attribute link
How to add a drawing creation date in a title block?
RE: Attribute link
How do you create title block?
CODE --> vb6
Set MyTextGetRevDate1 = MyDrawingViews.ActiveView.Texts.Add("" & Format(Date, "dd/MM/yyyy"), XLocDate, YLocDate)
MyTextGetRevDate1.Name = "RevisionBlock_Text_Date_" & Revision
MyTextGetRevDate1.SetFontSize 0, 0, 1.5
MyTextGetRevDate1.SetFontName 0, 0, "Century Gothic (TrueType)"
MyTextGetRevDate1.AnchorPosition = catMiddleCenter
Jenia Ladkov
RE: Attribute link
It's simple title block drawn with lines.How do I input this code?
