Design Tee and Barred Tee Datasheet
I am designing a tee barred but I do not find the dimensions of bicelado and chamflan to design the Tee and then proceed with the details of the welded bars, I would be very grateful to help me with some catalog or datasheet
RE: Design Tee and Barred Tee Datasheet
excuse my stupidity, what is barred, bicelado and chamflan?
Do you mean tees used in pigginglines?
bars, like a jail cell, for blocking a pig or sphere from taking a turn into the outlet of the tee.
Technology is stealing American jobs. Stop visas for robots.
bevel and chamfer according to google translate.
Still doesn't make a lot of sense.
I wouldn't bother - just say barred tee and then look at the design provided.
~you really want something like this
There are also versions where you weld the bars into a short section of the branch and then weld that onto the tee because the welding of the bars is then a lot easier.
Welding of the bars - really flat strips - is quite difficult to do and QA/testing is notoriously difficult.
"I am designing a barred tee" probably means he has to bother with it.
Good you gave him the std dwg.
I've used round bars instead of those flat bars you've got there.
LittleInch :
Correct that is what I am looking for.
regards
No.
Right click, save picture wherever you like.
Google wasn't good enough?
