Measuring 2D inertia properties Catvba
I am using CATIA command start to start c:measure inertia with a surface already selected by user. By default 3 D inertia properties are displayed but I need 2 D inertia properties. Is there any method I can start 2 d properties directly or any other way of doing this?
Play to Win
RE: Measuring 2D inertia properties Catvba
if you not familiar with win API and window handler then please google it.
Took me several days to get started... you'll need something like spy++ to 'read' windows and activate button. It is included in Visual studio 2015, not sure where it is in VS 2017...
Could anyone help me with the script to run measure 2D inertia after the line CATIA.StartCommand "Measure Inertia"
Or is there any other way I can measure the 2d moment of inertia , area and principal moments of a surface
Play to Win
You don't need to use CATIA.StartCommand "Measure Inertia", you need to use SPAWorkbench.
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
