Resin Rich between individual plys
This part is made by ATL machines using CFEP UD Tape
some parts have been rejected due to resin rich between individual plys after NDT inspection
I am trying to know how this issue happened though,
there was no any change in roller presure and No difference in bagging and cure process
Do you have any idea?
Someone told me that there would be some possibility that the contents of resin in raw material may cause this kind of resin rich
Thank you
Thank you
RE: Resin Rich between individual plys
Resin rich areas can come from material variations, low pressure in local areas ( bag bridging, tooling mismatch), etc.
B.E.
You are judged not by what you know, but by what you can do.
this resin rich occured over certain area of the entire area
