Flange clarification required
Dears ,
As my project 2500 gpm 9.7 bar centrifugal fire pump with ductile iron piping PN16 pressure rating.
in pump nozzle flange standard ANSI 125# B 16.1
all valves flange standard ANSI 150# B 16.5
Ductile iron flange standard PN16 or BSEN standard.
Since I need some clarification on below mentioned threads.
ANSI 125# B 16.1 flange dimension standard and flange hole, bolt size same with ANSI 150# B 16.5 flange
Ductile flanged piping possible to customize on ANSI 150# B 16.5 flange ?>
or else give any possible modification solution.
Thanks ,
Rajesh
Thanks ,
Rajesh
RE: Flange clarification required
Also add the flange face to your description. FF or RF. Iron flanges tend to be FF so you need valve flanges to match.
