Eurocode 3 Shear Verification
Good Morning at all
I have a question regarding to a design verification.
I have a connection that is composed by four M20 bolts, located at the extremity of an ideal square. As per Eurocode 3 this connection could be classified as Shear Connection - Category A Bearing Type.
Moreover because the bolt is M20 the difference between the bolt diameter and the hole diameter should be 2mm.
My concern is relative to :
1) the tightening torque to apply in order to assure the correct assembly, because anyway the Catergory A (shear connection) should respect the EN 15048-1:2007 (Non-preloaded structural bolting assemblies). Can I apply something 400Nm of torque?
2) How I have to consider the Sheat Load on the junction? To verify the bolt can I simply divide by four the total shear load acting on the junction? It is possible that the 2 mm of difference between the diametere of the hole and the bolt could bring to a non loaded bolt? Becuase some do not have contact to the plate. How many bolt I have to consider for the design? In the normative (UNI, Eurocode 3, etc...) where I can find this scenario?
Thanks for you answer
RE: Eurocode 3 Shear Verification
While bolts are not tensioned they are still torqued to a condition that would bring the assemblies into contact.
Not familiar with Eurocode, but the above is true of most codes for non tensioned bolts.
best regards
Klaus
