If I have a pipe above ground should I consider cathodic protection?
If I have a pipe above ground should I consider cathodic protection? Or in which cases cathodic protection is strictly required?
RE: If I have a pipe above ground should I consider cathodic protection?
No. It doesn't work.
When it's buried or underwater
Cathodic protection can, in principle, be applied to any metallic structure in contact with a bulk electrolyte. In practice its main use is to protect steel structures buried in soil or immersed in water. It cannot be used to prevent atmospheric corrosion.
By golly, this could open up a whole new field!
But you have to turn the current around to the other direction.
Otherwise you need lightning protection https://pgjonline.com/2014/02/18/lightning-a-new-k...
Technology is stealing American jobs. Stop visas for robots.
