[ABAQUS] Is it possible to run an .inp file written in 6.14-4 in an ABAQUS/Standard 6.14-1 version?
Hi Everybody,
I've been trying to run my first ABAQUS Job in my university's cluster; it has installed ABAQUS 6.14-1, while i can use only ABAQUS 6.14-4 in my PC.
When i try to run the Job from an .inp file in the cluster's server, i get this error:
Traceback (most recent call last):
File "SMAPyaModules/SMAPyaDriverPy.m/src/analysis.py", line 1278, in <module>
File "SMAPyaModules/SMAPyaDriverPy.m/src/analysis.py", line 1199, in run
File "SMAPyaModules/SMAPyaDriverPy.m/src/application.py", line 143, in run
File "SMAPyaModules/SMAPyaDriverPy.m/src/analysis.py", line 672, in validate
File "SMAPyaModules/SMAPyaDriverPy.m/src/analysis.py", line 869, in validateStandard
TypeError: int() argument must be a string or a number, not 'NoneType'
The only thing i can think about this issue is a compatibility issue, otherwise i really have no clue about what's going on.
Anybody has some advices to give me?
Thank you in advance.
Omar
Omar
RE: [ABAQUS] Is it possible to run an .inp file written in 6.14-4 in an ABAQUS/Standard 6.14-1 version?
Did you meanwhile solve the problem? I'm running into similar issues.
Thanks!
