Local Environment File - Subroutine Linking Issue
So I've always pre-compiled my subroutines using the "abaqus make" command and linked to the library using "usub_lib_dir" in the local (job folder) environment file (abaqus_v6.env / custom_v6.env). For some reason now I can't get this to work using the local environment file. Everything works fine with the "usub_lib_dir" line placed in the SMA/site environment file, but if I try to use it directly in the folder where I'm running the job I get the "Error, user subroutine X not found" in the message file.
Anyone have any thoughts?
