LTCS LCB/LCC/LF2 with impact test at -52°C
Dear all,
our client is asking us to specify LTCS material impact tested at -52°C. Anybody have any experience about values of impact tests at this Temperature for cast (A352-LCB/LCC) and forged (A182-LF2) grades?
Thank you in advance
RE: LTCS LCB/LCC/LF2 with impact test at -52°C
I have had experience with A-359 LF2 meeting B31.3 absorbed energy requirements at -52C. None with casting suppliers for your materials. You need to ask your suppliers.
I have gone a bit lower than -50°F but with a lower carbon and higher Mo chemistry than what is usually done with LCC/LCB. I would suggest that you recommend LC1 as it is designed to go to a lower temperature.
As a casting supplier I would not want to accept an order with LCC/LCB with impacts at a test temperature lower than the specification as my weld repair procedures were not qualified at that temperature.
