Calculate flow rate in l/min from bar
I have a nitrogen tank 200bar 11L with 1/4 SAE screwed connector. An 1800mm long hose 10mm diameter is attached. The regulator wheel is from 0 to 50 bar output. I need to be able to set the flow rate in l/min, not bar.
How do I calculate this?
RE: Calculate flow rate in l/min from bar
Only if you know what pressure in your downstream system equates to your flow can you determine this.
Or fit a flow meter or cone type meter and then adjust pressure to suit.
Like this
Technology is stealing American jobs. Stop visas for robots.
