Surface acoustic wave (SAW) sensor, frequency response simulation in ANSYS
Hello guys,
I'm trying to simulate a SAW sensor in ANSYS, but I can't get it done and experience some solving problems. I hope you can help me.
I would like to get the frequency response, admittance, deformation etc. but I even fail to simulate the frequency response respectively run the example file successfully.
Here is the PDF which explains a bit what I want to do, see page 14: http://www.ozeninc.com/wp-content/uploads/2015/05/...
This is how it looks like:
Big: http://www.jogibaerspace.de/01_ansys.jpg
So in my opinion the best idea is to use the rebuilt example file (2nd link) for analysis, because the other one produces more errors, also concerning units that I decided to build it again before waisting more time.
ANSYS 17.2
Original example file by ANSYS: http://www.jogibaerspace.de/saw_harmonic_pml_17.wb...
Rebuild example file: http://www.jogibaerspace.de/SAW.wbpz
My rebuilt ends up with this error message:
An unknown error occurred during solution. Check the Solver Output on the Solution Information object for possible causes.
Here is the solver output:
CODE -->
Solver Output
 ANSYS Multiphysics
          *****  ANSYS COMMAND LINE ARGUMENTS  *****
  BATCH MODE REQUESTED (-b)    = NOLIST
  INPUT FILE COPY MODE (-c)    = COPY
  DISTRIBUTED MEMORY PARALLEL REQUESTED
       2 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
    TOTAL OF     2 CORES REQUESTED
  MPI OPTION                   = INTELMPI
  INPUT FILE NAME              = C:\Pfad\ANSYS\_ProjectScratch\Scr6481\dummy.dat
  OUTPUT FILE NAME             = C:\Pfad\ANSYS\_ProjectScratch\Scr6481\solve.out
  START-UP FILE MODE           = NOREAD
  STOP FILE MODE               = NOREAD
 RELEASE= Release 17.2         BUILD= 17.2      UP20160718   VERSION=WINDOWS x64
 CURRENT JOBNAME=file0  16:43:35  MAY 24, 2017 CP=      0.625
 PARAMETER _DS_PROGRESS =     999.0000000
 /INPUT FILE= ds.dat  LINE=       0
 *** NOTE ***                            CP =       0.719   TIME= 16:43:35
 The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
 solution.  Command is ignored.
 *GET  _WALLSTRT  FROM  ACTI  ITEM=TIME WALL  VALUE=  16.7263889
 TITLE=
 SAW--Harmonic Response (B5)
  ACT Extensions:
      Acoustics, 172.7
      133706f2-c6fb-43e5-925f-c762e75c8c93, wbex
 /COM,     PiezoAndMEMS, 172.1
      0cd64874-101b-4182-aef8-530cf9982bb6, wbex
 SET PARAMETER DIMENSIONS ON  _WB_PROJECTSCRATCH_DIR
  TYPE=STRI  DIMENSIONS=      248        1        1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = C:\Pfad\ANSYS\_ProjectScratch\Scr6481
 SET PARAMETER DIMENSIONS ON  _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = C:\Pfad\ANSYS\SAW_files\dp0\SYS\MECH
 SET PARAMETER DIMENSIONS ON  _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = C:\Pfad\ANSYS\SAW_files\user_files --- Data in consistent MKS units. See Solving Units in the help system for more
 MKS UNITS SPECIFIED FOR INTERNAL
  LENGTH        (l)  = METER (M)
  MASS          (M)  = KILOGRAM (KG)
  TIME          (t)  = SECOND (SEC)
  TEMPERATURE   (T)  = CELSIUS (C)
  TOFFSET            = 273.0
  CHARGE        (Q)  = COULOMB
  FORCE         (f)  = NEWTON (N) (KG-M/SEC2)
  HEAT               = JOULE (N-M)
  PRESSURE           = PASCAL (NEWTON/M**2)
  ENERGY        (W)  = JOULE (N-M)
  POWER         (P)  = WATT (N-M/SEC)
  CURRENT       (i)  = AMPERE (COULOMBS/SEC)
  CAPACITANCE   (C)  = FARAD
  INDUCTANCE    (L)  = HENRY
  MAGNETIC FLUX      = WEBER
  RESISTANCE    (R)  = OHM
  ELECTRIC POTENTIAL = VOLT
 INPUT  UNITS ARE ALSO SET TO MKS
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM  RELEASE Release 17.2     17.2     ***
 DISTRIBUTED ANSYS Multiphysics
 00000000  VERSION=WINDOWS x64   16:43:35  MAY 24, 2017 CP=      0.719
          ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "End_Tx" ***********
 *********** Elements for Body 2 "End_Tx_subs" ***********
 *********** Elements for Body 3 "Solid" ***********
 *********** Elements for Body 4 "Solid" ***********
 *********** Elements for Body 5 "Solid" ***********
 *********** Elements for Body 6 "Solid" ***********
 *********** Elements for Body 7 "Solid" ***********
 *********** Elements for Body 8 "Solid" ***********
 *********** Elements for Body 9 "Solid" ***********
 *********** Elements for Body 10 "Solid" ***********
 *********** Elements for Body 11 "Solid" ***********
 *********** Elements for Body 12 "Solid" ***********
 *********** Elements for Body 13 "Solid" ***********
 *********** Elements for Body 14 "Solid" ***********
 *********** Elements for Body 15 "Solid" ***********
 *********** Elements for Body 16 "Solid" ***********
 *********** Elements for Body 17 "Solid" ***********
 *********** Elements for Body 18 "Solid" ***********
 *********** Elements for Body 19 "Solid" ***********
 *********** Elements for Body 20 "Solid" ***********
 *********** Elements for Body 21 "Solid" ***********
 *********** Elements for Body 22 "Solid" ***********
 *********** Elements for Body 23 "Tx_Si" ***********
 *********** Elements for Body 24 "Tx_subs" ***********
 *********** Elements for Body 25 "End_Rx_Si" ***********
 *********** Elements for Body 26 "End_Rx_subs" ***********
 *********** Elements for Body 27 "Solid" ***********
 *********** Elements for Body 28 "Solid" ***********
 *********** Elements for Body 29 "Solid" ***********
 *********** Elements for Body 30 "Solid" ***********
 *********** Elements for Body 31 "Solid" ***********
 *********** Elements for Body 32 "Solid" ***********
 *********** Elements for Body 33 "Solid" ***********
 *********** Elements for Body 34 "Solid" ***********
 *********** Elements for Body 35 "Solid" ***********
 *********** Elements for Body 36 "Solid" ***********
 *********** Elements for Body 37 "Solid" ***********
 *********** Elements for Body 38 "Solid" ***********
 *********** Elements for Body 39 "Solid" ***********
 *********** Elements for Body 40 "Solid" ***********
 *********** Elements for Body 41 "Solid" ***********
 *********** Elements for Body 42 "Solid" ***********
 *********** Elements for Body 43 "Solid" ***********
 *********** Elements for Body 44 "Solid" ***********
 *********** Elements for Body 45 "Solid" ***********
 *********** Elements for Body 46 "Solid" ***********
 *********** Elements for Body 47 "Rx_Si" ***********
 *********** Elements for Body 48 "Rx_subs" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
 *********** Create Contact "Contact Region" ***********
             Real Constant Set For Above Contact Is 50 & 49
 *********** Create Contact "Contact Region 2" ***********
             Real Constant Set For Above Contact Is 52 & 51
 *********** Create Contact "Contact Region 3" ***********
             Real Constant Set For Above Contact Is 54 & 53
 *********** Create Contact "Contact Region 4" ***********
             Real Constant Set For Above Contact Is 56 & 55
 *********** Create Contact "Contact Region 5" ***********
             Real Constant Set For Above Contact Is 58 & 57
 *********** Create Contact "Contact Region 6" ***********
             Real Constant Set For Above Contact Is 60 & 59
 *********** Create Contact "Contact Region 7" ***********
             Real Constant Set For Above Contact Is 62 & 61
 *********** Create Contact "Contact Region 8" ***********
             Real Constant Set For Above Contact Is 64 & 63
 *********** Create Contact "Contact Region 9" ***********
             Real Constant Set For Above Contact Is 66 & 65
 *********** Create Contact "Contact Region 10" ***********
             Real Constant Set For Above Contact Is 68 & 67
 *********** Create Contact "Contact Region 11" ***********
             Real Constant Set For Above Contact Is 70 & 69
 *********** Create Contact "Contact Region 12" ***********
             Real Constant Set For Above Contact Is 72 & 71
 *********** Create Contact "Contact Region 13" ***********
             Real Constant Set For Above Contact Is 74 & 73
 *********** Create Contact "Contact Region 14" ***********
             Real Constant Set For Above Contact Is 76 & 75
 *********** Create Contact "Contact Region 15" ***********
             Real Constant Set For Above Contact Is 78 & 77
 *********** Create Contact "Contact Region 16" ***********
             Real Constant Set For Above Contact Is 80 & 79
 *********** Create Contact "Contact Region 17" ***********
             Real Constant Set For Above Contact Is 82 & 81
 *********** Create Contact "Contact Region 18" ***********
             Real Constant Set For Above Contact Is 84 & 83
 *********** Create Contact "Contact Region 19" ***********
             Real Constant Set For Above Contact Is 86 & 85
 *********** Create Contact "Contact Region 20" ***********
             Real Constant Set For Above Contact Is 88 & 87
 *********** Create Contact "Contact Region 21" ***********
             Real Constant Set For Above Contact Is 90 & 89
 *********** Create Contact "Contact Region 22" ***********
             Real Constant Set For Above Contact Is 92 & 91
 *********** Create Contact "Contact Region 23" ***********
             Real Constant Set For Above Contact Is 94 & 93
 *********** Create Contact "Contact Region 24" ***********
             Real Constant Set For Above Contact Is 96 & 95
 *********** Create Contact "Contact Region 25" ***********
             Real Constant Set For Above Contact Is 98 & 97
 *********** Create Contact "Contact Region 26" ***********
             Real Constant Set For Above Contact Is 100 & 99
 *********** Create Contact "Contact Region 27" ***********
             Real Constant Set For Above Contact Is 102 & 101
 *********** Create Contact "Contact Region 28" ***********
             Real Constant Set For Above Contact Is 104 & 103
 *********** Create Contact "Contact Region 29" ***********
             Real Constant Set For Above Contact Is 106 & 105
 *********** Create Contact "Contact Region 30" ***********
             Real Constant Set For Above Contact Is 108 & 107
 *********** Create Contact "Contact Region 31" ***********
             Real Constant Set For Above Contact Is 110 & 109
 *********** Create Contact "Contact Region 32" ***********
             Real Constant Set For Above Contact Is 112 & 111
 *********** Create Contact "Contact Region 33" ***********
             Real Constant Set For Above Contact Is 114 & 113
 *********** Create Contact "Contact Region 34" ***********
             Real Constant Set For Above Contact Is 116 & 115
 *********** Create Contact "Contact Region 35" ***********
             Real Constant Set For Above Contact Is 118 & 117
 *********** Create Contact "Contact Region 36" ***********
             Real Constant Set For Above Contact Is 120 & 119
 *********** Create Contact "Contact Region 37" ***********
             Real Constant Set For Above Contact Is 122 & 121
 *********** Create Contact "Contact Region 38" ***********
             Real Constant Set For Above Contact Is 124 & 123
 *********** Create Contact "Contact Region 39" ***********
             Real Constant Set For Above Contact Is 126 & 125
 *********** Create Contact "Contact Region 40" ***********
             Real Constant Set For Above Contact Is 128 & 127
 *********** Create Contact "Contact Region 41" ***********
             Real Constant Set For Above Contact Is 130 & 129
 *********** Create Contact "Contact Region 42" ***********
             Real Constant Set For Above Contact Is 132 & 131
 *********** Create Contact "Contact Region 43" ***********
             Real Constant Set For Above Contact Is 134 & 133
 *********** Create Contact "Contact Region 44" ***********
             Real Constant Set For Above Contact Is 136 & 135
 *********** Create Contact "Contact Region 45" ***********
             Real Constant Set For Above Contact Is 138 & 137
 *********** Create Contact "Contact Region 46" ***********
             Real Constant Set For Above Contact Is 140 & 139
 *********** Create Contact "Contact Region 47" ***********
             Real Constant Set For Above Contact Is 142 & 141
 *********** Create Contact "Contact Region 48" ***********
             Real Constant Set For Above Contact Is 144 & 143
 *********** Create Contact "Contact Region 49" ***********
             Real Constant Set For Above Contact Is 146 & 145
 *********** Create Contact "Contact Region 50" ***********
             Real Constant Set For Above Contact Is 148 & 147
 *********** Send Named Selection as Element Component ***********
 *********** Send Named Selection as Node Component ***********
 *********** Fixed Supports ***********
 ********* Frictionless Supports X *********
 ***** ROUTINE COMPLETED *****  CP =         2.297
 --- Number of total nodes = 249363
 --- Number of contact elements = 35164
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 48822
 --- Number of total elements = 83986
 *GET  _WALLBSOL  FROM  ACTI  ITEM=TIME WALL  VALUE=  16.7266667
 *****  ANSYS SOLUTION ROUTINE  *****
 PERFORM A HARMONIC ANALYSIS
  THIS WILL BE A NEW ANALYSIS
 HARMONIC FREQUENCY RANGE - END= 0.10000E+09  BEGIN= 0.50000E+08
 PERFORM A FULL HARMONIC RESPONSE ANALYSIS
 THERMAL STRAINS ARE NOT INCLUDED IN THE LOAD VECTOR.
 STEP BOUNDARY CONDITION KEY= 1
 USE    10 SUBSTEP(S) THIS LOAD STEP FOR ALL  DEGREES OF FREEDOM
 DAMPING RATIO =      0.0100
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL  ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
   FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 ***********  Piezoelectric Body1 ***********
 CMBLOCK read of NODE component PIEZOELECTRICBODY1  completed
 FINISH SOLUTION PROCESSING
 ***** ROUTINE COMPLETED *****  CP =         2.359
 00000000  VERSION=WINDOWS x64   16:43:36  MAY 24, 2017 CP=      2.359
 SELECT      COMPONENT PIEZOELECTRICBODY1
 SELECT      ONLY ELEMENTS COMPLETELY CONTAINED WITHIN NODE SET.
    77000 ELEMENTS (OF    83986  DEFINED) SELECTED FROM
   222662 SELECTED NODES BY  ESLN COMMAND.
 RESELECT     FOR ITEM=ENAM COMPONENT=
  IN RANGE       185 TO        185 STEP          1
          0  ELEMENTS (OF      83986  DEFINED) SELECTED BY  ESEL  COMMAND.
 *GET  INUM185   FROM  ELEM  ITEM=COUN           VALUE=  0.00000000
 *IF  iNum185                           ( =   0.00000     )  GT
      0                                 ( =   0.00000     )  THEN
 ***** ROUTINE COMPLETED *****  CP =         2.422
 EXIT ANSYS WITHOUT SAVING DATABASE
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          0
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          0
+--------- D I S T R I B U T E D   A N S Y S   S T A T I S T I C S ------------+
Release: Release 17.2       Build: 17.2       Update: UP20160718   Platform: WINDOWS x64
Date Run: 05/24/2017   Time: 16:43
Operating System: Windows 10  (Build: 15063)
Windows Process ID: 3504
Processor Model:         Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Compiler: Intel(R) FORTRAN Compiler Version 15.0.2  (Build: 20150121)
          Intel(R) C/C++ Compiler Version 15.0.2  (Build: 20150121)
          Intel(R) Math Kernel Library Version 11.2.3 Product Build 20150413
Number of machines requested            :    1
Total number of cores available         :    8
Number of physical cores available      :    4
Number of processes requested           :    2
Number of threads per process requested :    1
Total number of cores requested         :    2 (Distributed Memory Parallel)
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 5.0 Update 3 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
  Core                Machine Name   Working Directory
     0              electric_ocean   C:\Pfad\ANSYS\_ProjectScratch\Scr6481
     1              electric_ocean   C:\Pfad\ANSYS\_ProjectScratch\Scr6481
Latency time from master to core    1 =    0.556 microseconds
Communication speed from master to core    1 =  6075.34 MB/sec
Total CPU time for main thread                    :        1.8 seconds
Total CPU time summed for all threads             :        2.8 seconds
Elapsed time spent pre-processing model (/PREP7)  :        1.0 seconds
Elapsed time spent solution - preprocessing       :        0.0 seconds
Elapsed time spent computing solution             :        0.0 seconds
Elapsed time spent solution - postprocessing      :        0.0 seconds
Elapsed time spent post-processing model (/POST1) :        0.0 seconds
Maximum total memory used                         :      149.0 MB
Maximum total memory allocated                    :     3136.0 MB
Maximum total memory available                    :          8 GB
+------ E N D   D I S T R I B U T E D   A N S Y S   S T A T I S T I C S -------+
 |                       DISTRIBUTED ANSYS RUN COMPLETED                     |
 | Ansys Release 17.2          Build 17.2         UP20160718     WINDOWS x64 |
 | Database Requested(-db)  1024 MB    Scratch Memory Requested      1024 MB |
 | Maximum Database Used     112 MB    Maximum Scratch Memory Used     32 MB |
 |        CP Time      (sec) =          2.766       Time  =  16:43:37        |
 |        Elapsed Time (sec) =          4.000       Date  =  05/24/2017      |
